should terminal 1 have power on it and if so where does it come from.my does not with or without the switch on even when cranking.sensor coils 1&3 7.5 ohms 2&4 8.0 ohms. no short to ground. charging coils 837 ohms. no spark any where.replace all coils as 1 was bad. terminals 2,4,9,12 has nothing coming out of them.I did check the fuse on the block and it is good.
