southcarolinaf150
- Feb 4, 2014
- 11
Mounting this motor on my boat, removed it from a 16' Baja. I be run into some confusion with the trim tilt wiring, any help is appreciated
First pic is what I have coming from the remote control:
http://s610.photobucket.com/user/Br...Uploads/image_zpsygwdpmfw.jpg.html?sort=3&o=2
This is what I have coming for the motor end. The wires on the bottom appear to go into the solenoid? not the tilt motor:
http://s610.photobucket.com/user/Br...Uploads/image_zpsrnv9f0nv.jpg.html?sort=3&o=1
I remember that the blue and green (up/down) were definitely connected to each other but the red coming from the control as well as the black from the motor (I would assume it is the ground to battery) and the two other wire coming out are what I can't remember how they were.
I should say this is my first time messing with power trim as I've only had smaller motors before
Thanks
Thanks
