saltwaterbluefish
- Dec 14, 2010
- 156
Outboard: 1977 115 hp Johnson
I have been tracing a gremlin in my boats electrical system that I seem to not be able to figure out.
Issue: When I turn the key, I get a click and what sounds like a sizzle.
The battery did have corrosion built up on the negative terminal, but after cleaning, a good charging and a test at an auto store the battery does not appear to be the issue. Moved on to the solenoid. It had the original equipment and with the starter unhooked I heard the click. Replaced and did not fix the problem. The starter was suffering from a pretty bad case of rust (original equipment as well) and I got a pretty good deal on a brand new one so I put a new one on. Still have the issue.
All the connections look clean and wires seem to be in good shape. I can get the motor started usually on the 4th to 5th time I turn the key. The motor runs great once it gets going, but I hate to go out on the water and not be able to get back. Last year put a new powerpack, ignition coils and rectifier as well as new spark plugs when I rebuilt the carbs a few weeks ago.
Any suggestions would be appreciated as I am lost at the moment.
