Re: 1979 evinrude 115hp timer base
This most often happens just after start up. The engine acts like it is running on three cyl. for about 1-2 min. as I try to accellerate. Then it kicks in and may run fine the rest of the day including many stops. I warm it up good and it takes me 5 min. to idle out of the harbor. Then it just doesn't run right for that 1-2 min. Real big loss of power then it takes off great. Could the timer base be hanging up on its rotating bearing.
