avisalem155
- May 29, 2015
- 32
Hi All,
I recently acquired a 16' bowrider with a 1994 Johnson 70 ELERC (3 cylinder 2 stroke). I have rebuilt the carbs already and replaced some fuel lines and primer bulb setup. The problem I am having is that under load, the boat won't break 3,000 rpms. I pulled the coils, boots, and spark plugs, and it seems as if the middle cylinder isn't firing. I assume this because when I pulled the boot off the plug, the rpms didn't drop at all. Switched around coils and everything and still no change when pulling the boot for the middle carb. I actually pulled the boot off by hand for all 3 plugs (yep nice shock), but the middle carbs shock didn't seem to zap me as bad. Could it be the powerpack? I just got a spark tester and compression tester and will perform those tests tomorrow. How should I go about testing the ignition system?
Thanks,
Avi
Thanks,
Avi
