nphilbro
- Dec 19, 2011
- 304
I was curious if these motors came with a tilt lock for the up position. It works fine in the down lock but I don't see anywhere on the motor that will keep it locked in the up position. I'm just going to use it or trolling so need to pull it up when I run the main motor. If necessary, I have an older OMC hydraulic assist lift bracket but it needs new bushings, a transom wedge, and a few stainless replacement bolts before it can be mounted. Ocean salmon season opens this weekend so id rather get the boat ready than rebuild the bracket.
