Captain Bravo
- Jul 2, 2011
- 37
This motor is severely lacking power at anything more than 1/3 throttle. This is what I have done. New spark plugs, stator, rectifier, timer base with sensor, cleaned and adjusted carbs, cleaned and inspected fuel pump, replaced all fuel lines & bulb, and has fresh gas. Timing is perfect, throttle is opening all the way, compression is 155# both cylinders. Throws a bright blue spark 7/16". Honestly everything I check on this motor tests out as perfect.
It was (supposedly) rebuilt a few years ago. When I first got this engine it ran great for about 20 minutes. Then it started losing power at higher throttle settings. Last fall, it would start and run fine at idle and high idle. It would stay running at full throttle, but it didn't have any more power than half throttle.
This spring, it doesn't want to idle well, and it seems to be lacking power even more than last year. To start, lift warm up lever, choke it for a few revolutions, and then let off the choke. After it starts let it rev a little, then drop the warm up lever with one hand and advance throttle with the other. It will usually go, but is severely lacking power.
I wondered about a crank seal, but the spark plugs look OK, and there seems to be a good pressure pulse at the fuel pump line. Here is a link to pics of the spark plugs and short video of the pressure pulse.
http://s172.photobucket.com/user/Maggsters_pics/library/50hp Johnson 50ESL73R
What else should I check?
