I have a Johnson 115HP 2 stroke that starts without issue and initially goes into gear and runs. After only a few minutes, the engine stalls and will start again but once put into gear stalls. This goes on to the point I can no longer put the engine into gear as the engine immediately stalls.
The engine started up immediately after the winter storage and still starts fine. Apparently once under load and entered into gear, it stalls. Any help is appreciated.
