Woodbinekeith
- Sep 1, 2009
- 86
I just picked up a boat with the 115 VRO. It starts/runs fine but the seller told me it was not charging the battery. Have done some research and it seems that the probable replacement is the rectifier/regulator at about $200 +-. Tilt/trim works fine.
The rectifier is not in plain sight on the starboard side of the engine. The yellow and red/red grey wires are leading from the buss bar up under the flywheel so it seems that the flywheel must be removed to get at the rectifier.
I bought a $7 rectifier (4 terminal) that apparently has been successfully used in motors that have the rectifier in plain sight. It is rated as "up to 1000V and 50 amps." This sounds like high for the voltage but is the only one available.
Once the flywheel has been pulled, will this rectifier fit on my motor, or will it even work as a replacement on my motor. From a picture, the OEM replacement rectifier seems to be considerably flatter that the one I picked up so am wondering if there is room to put the replacement in.
