Hi All, i recently tried to replace the flywheel on my outboard, and when i got the old flywheel off, i noticed some damage underneath it.
See attached link for the parts i am referencing
SO... i went to install the new flywheel, and i found that number 26 (stator assy.) looks to be cracked in a few places and rubbing on the magnets on the inside of my old flywheel. There is also some play in the whole assembly (stator, plate...). I should probably replace this, but i read somewhere else that there was a "kit" you could buy to resolve the issue with the play. Does anybody know of this kit? I think this contributes to the other issue, that when i jog the flywheel by hand, it appears to "catch" the stator and rotate the plate a little. I think this could be the magnets touching. Can anybody shed a little light to what is going on here?
Thank you
Thank you
