Tim Frank
- Jul 29, 2008
- 5,333
Due to incompetence (mine unfortunately so nobody else to blame), I have to R&R the lower unit on this little gem.
I have a problem with availability of the roll pin that supports the Driveshaft-crankshaft seals etc.
It's available, but will take some time to arrive.
The local dealer says to bring in the bent one and they can probably match up one a bit longer and i can cut or grind it to length.
Does anyone have any idea what the length tolerance would be? Intuitively they would have used a stock pin from somewhere, so i could probably get a match from a bearing and equipment shop, but if tolerance is not critical, grinding to size would work.
Also,how can you be sure that all those parts are still "aligned and stacked" as they should be and that nothing has moved?
