bobgritz
- Sep 22, 2009
- 185
I'm a commercial clammer and we go out 365/7 weather permitting. After irregular high tides the bay has random floating salt marsh hay and I managed to snag enough which covered my water intake for no more than 30-45 seconds. The engine stalled and was red hot to the touch. After cooling off it reluctantly ran but not well and compression measured 60 top and 30 bottom. I pulled the head hoping to just replace the gasket and maybe re-plane the head. Correct me if I'm wrong but the head appears to be junk and obviously the pistons should be replaced but if I can get 75+- pounds in top and bottom it will be fine for my use (our motors have a tough life and need overhauls every couple of years). The cylinder walls looked ok. My question is ... can I just replace this head and get away with the scorched pistons? I don't need stellar performance but I also don't want to waste more time and do something evil to the rest of the motor without knowing it. I'm using a similar (15 HP) backup motor that will probably find its way onto my workbench fail in about 2 years but I just need to get this one back on it's feet so it can be ready to come off the bench when needed.
