concealed side mounted control omc. engine is a 2003 Johnson 115hp 4 stroke.
the local shop sold me the same cable for the feeder and the shift could that be the problem...
when the cable is installed in hole 1 I have forward ok but enable to move it to revers has the cable is max out before it engage. if in hole #2 I have full revers but cannot put in forward gear has its max out before engaging...
