tomb198269
- Mar 26, 2015
- 11
Hello,
I ran WOT for about twenty to thirty minutes up and down the river. Then I heard the continuous beep from console. Oil level is good, using 87 octane non ethanol gas. The motor does not shut off but does not go fast. I am assuming its a safety from overheating. Because i cannot go WOT it just bucks. I have not changed the impeller as well. It shoots a strong stream of water out of the pisser, so I am as assuming the water pump is good? Could it be running to lean?
Some thing I have done.
New fuel line
changed oil
new fuel filter
rebuilt/clean carburetors
good compression
Thanks
Thomas
New fuel line
changed oil
new fuel filter
good compression
Thanks
Thomas
