Should the little white mushroom (or piston) shaped plastic piece internal to the fuel pump which is spring loaded and whose post sticks through the small hole in the back of the pump when the spring is compressed be poking in and out as the pump operates with the engine running?
My engine is running fine at idle but surges and oscillates when in gear and run anywhere above about mid throttle. I never see that white post stick out of the fuel pump unless I squeeze the primer ball hard then it comes out. Should it not pop in and out on occasion as the pump runs?
Anyone understand that explanation? Sorry....
