Hello All,
I have a 1973 Johnson 6 Hp Model 6R73S. I removed the starter to access the carb nuts to repair the carb. The spring for the recoil starter unwound itself in a hurry.
When I put it all back together I cannot get the spring to take up the pull cord. When I go to rewind the spring it sounds as though something has come out of a retainer slot or something similar. I am unable to remove the spring from the bottom retainer to see what the problem is. How do I get the mainspring loose from the bottom retainer to check for broken or misaligned parts? I do not want to damage the mainspring.
Thanks
rcb130
Thanks
rcb130
