MMarshall88
- Jun 14, 2012
- 26
I got a 87 astroglass boat with a 87 Johnson 150 GT that's having the alarm go off. I know it's not the overheat alarm. It has new water pump and head temp on them. I noticed last year my boat would run fine wide open. Then at times the alarm would come on and after a minute or 2 , the engine would start to bogg down. I would look at the primer bulb and it would be sucked in like someone was squeezing it all the tight. I changed every hose going from the tank to the pump. Changed fuel filter and primer bulb. Also checked the valve on the tank to make sure that ball wasn't hung and someone had already taken it out. I also took out the gas tank and drained the tank to make sure there was no debree in there and to make sure the line wasn't clogged as well. I also checked the vent line and all seemed fine. Took it out On the lake for the first time today since last year and it rode fine until we started to head back to the dock from a fishing hole and the alarm came back on. It was a constant beep. Went to check the primer bulb it partially squeezed together and it was like someone was sucking the air out of the it on the other end. It wouldn't release. so I'm not sure what's going on and what it could be. I hope it isn't something leading to the VRO pump going bad. But the pump sucking the bulb down would tell me it still has pressure. I also read something about a vacuum pulse there too. If anyone has any idea what it could be without having to take to a dealer and pay a ton of money. Or if anyone else has any suggestions. Thanks.
