Hello all
I have a new to me 1991 evinrude 60 3cyl on a 1991 tracker nitro 160
Ive had this boat out a few times no issues what so ever
When i started the boat yesterday i heard a beeep beep beeep beeep beep beeep right off the bat, drove around everything worked fine , shut motor off then started an hour later and again as soon as she fires up , beeeep beeep beeep beeep lasts about 30 seconds
,i think it sputtered at idle because it died when i loaded it on the trailer but out on the water i got to WOT no problem
The vro tank has clearly been replaced by a new modern tank im not sure if that helps ,
Thanks for any insight
