I just bought a 1976 35 HP Evinrude model 35653S. To be safe, I dropped the lower unit, changed the water pump and plate, drained the gear case oil and refilled. I then got a storage tote, filled it full of water and fired up the motor. It started right away, but I noticed immediately that water was not coming out of the two holes in the exhaust housing so I stopped the motor, after running it for about 30 seconds.
Does it need to be running longer for water to come out? Does the motor need to be submersed in something larger than a storage tote to prime the pump? Did I screw something up when I replaced the water pump? Does the water hose need to go into a specific hole in the exhaust housing? When I dropped the lower unit, the water tube remained attached to the lower unit. I'm hesitant to put it on the water until I figure out if I did something wrong.
Thanks for the help!
Dan
Dan
