So after a lot of tinkering, I finally took my motor into a mechanic I have used for years and trust. The motor would idle fine, but when given full throttle, it just wouldn't pick up speed, like it had no power. Would only go about 10 mph. Btw this is on a 16 ft fiberglass v hull. All 3 cylinders were firing, spark was good, I rebuilt the carbs, put a new 15x13.75 prop on it, and it helped, but still would only go maybe 12 mph. I took it to him, first test he did was a compression leak test, and turns out the cylinders are leaking around 60% compression. Rings are fried :-/ mechanic says it needs a power head replacement, and it would cost around 900-1000 bucks. My question.....Is it worth it to rebuild this one and know what is in it, or look for a new outboard? My boat has a 105 hp limit. Thanks for any input.
