I have both and the johnson is far better looking, can I use parts from the evinrude on the johnson?
W whytimmywhy Recruit Joined Apr 26, 2015 Messages 1 Apr 26, 2015 #1 I have both and the johnson is far better looking, can I use parts from the evinrude on the johnson?
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,195 Apr 26, 2015 #2 Some of them, yes. Most of them no. There are many obvious differences because of the years.
Chinewalker Fleet Admiral Joined Aug 19, 2001 Messages 8,902 Apr 27, 2015 #3 Lower units & clamp brackets swap around. Exhaust housings may. Recoils interchange. Tillers interchange. Crankshaft and internals should. Blocks & cylinder heads will not. Carbs will, with some parts swapping for choke linkages.
