1989 Johnson GT150 Crank Pitting
sundaydrive86
Hello,
I received this motor for free through a friends divorce. To know what I had I took it apart to check it out. Everything looked good but there was one journal on the crank that had some light pitting. Let me know what you guys think. Will it be fine? Or is it junk? Thank you.
TK
I would not call that light pitting.---The rod likely had water sitting on it as well.-------That crank is scrap.------------Lots of good used ones on E-Bay.
emdsapmgr
Agree. Get a replacement crank. You'll want to know where the water came from before you try to run any rebuilt powerhead. Check the fuel tank and oil tank for water at the bottom.
