woodstockmarine
- May 6, 2012
- 37
The problem is when I turn the key no clicking , cranking , Nothing
The pushing choke works.
Jump the solenoid and it cranks.
First thing I checked the fuse on the motor and it looked good but the glass was cracked ( I might have done that taking it apart) so I put in a new fuse and the same thing.
Second I ordered a new solenoid from boats .net installed it and nothing.
Thought is may be the key switch.
I took apart the remote controls and the neutral safety switch is in good working condition. I have pwer to the switch when i turn the key to start and power coming out of the switch when it is engaged.
so i think the key switch is good.
When the key os turned on to just power I have juice to the top 3 leads on the terminal block.
I have an exposed wire coming out of the rectifier but it is not broken and not shorting and is one f the wires that are hot when the key is on.
Could it still the key switch?
Could it still be the solenoid ? No clicking at all.
Yes i have a good ground.
Could it be the power pack? I have not taken it apart yet but their is some surface corrosion on the outside.
so any help with the direction I should go or a check that I haven't done yet would be GREAT
Thanks
Thanks
