Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
83 70hp johnson no spark
  • 83 70hp johnson no spark
    I have a 1983 70 hp Johnson that lost spark to all 3 cylinders while i was at full throttle.Checked for spark and there was none at all.Does a power pack supply power to the individule cylinder coils?Im sure my problem is electrical.Any help would be great.Thanx.
    Re: 83 70hp johnson no spark
    First confirm that your problem is not in the ignition switch or safety lanyard button.I wound then perform a voltage test of the stator as per manual instructions and make sure its putting out.May be a powerpack failure , but you'll want to confirm before just buying another one.Those things are pricey.
    • #3
      Powerpack may be pricey but not near as pricey as the stator. I just had to replace the powerpack, stator, and rectifier on my 70 Evenrude.Ob has good advice. Might want to check your rectifier also. Mine was shorted to ground and may have caused the other problems?? If you have never worked on an outboard before, then grab a manual and get started. There is a lot of help on this site.
      • #4
        This help I got from Joe Reeves on my June 26th postIf no spark or a weak spark, disconnect the large RED electrical connector at the engine. Crank the engine by energizing the solenoid with a jumper (Bat term to small 3/18" nut term). If you now have spark, replace the ignition switch.Also Make sure all the connections are tight and clean at the power pack. After I checked all the connections I had spark on 2 cyl.I did have to replace the power pack on my motor1982 70 hp johnson.
        • #5
          thanx for the help gents I'll try those ideas.
