So the last few times I've been out I'll take off and the engine will suddenly lose power for about a half second like it lost spark then immediately recover and be just fine. This only happens once or twice a day. Today it happened while idlin and the motor completely died. Did that a couple times. I also noticed that my fuel gauge and water pressure gauge weren't working anymore. The beep would sound when I turned the key on, but the gauges wouldn't tick down like normal. I loaded the boat and tried when I got home. The gas gauge is working again now. Could this be an ignition switch problem?
