MMarshall88
- Jun 14, 2012
- 26
I have a 1987 Johnson GT outboard motor and I'm looking to add a temp gauge. I'm about to buy a set of faria gauges for my boat as i have restored it. And I've noticed after reading some threads that I can add either a water temp gauge or a cylinder head gauge. But I can't find on my motor to where I can pull out a plug to install a Water temp sender. Some say that there should be a blind hole to install and others I've read says I need to drill and tap a hole. I'm wanting to know if anyone knows where I can do this or should I use a bracket to attach the sender to the head to read the temp. All I'm seeing from the faria gauges is the water temp gauge. One gauge comes with a sender and reads 60-220 degrees and the other comes with no sender and the other reads 100-250 degrees with no sender. I'm really confused as to whether these temp gauges will work against the head on a bracket. They say water temp gauges. I see no where the faria gauges do they offer a cylinder head gauge with sender. I've also read that everyone seems to prefer the sender against the head vs reading the water temp. I'm also installing a water pressure gauge but that is simple to hook up on this motor. I'm really confused on what to do. I know if this will work on the heads, I will install one for each head and install 2 gauges on my boat to read each head. If anyone has any info on this please let me know as I am supposed to purchase the gauges next week when my new dash and toggle switches and wiring are complete. Thanks.
