Hi Folks,
Quick prop question. I was servicing my prop / shaft this afternoon, and when I removed it from the shaft, I noticed that a part of it does not normally move within the prop assembly itself is spinning freely. It's the cylindrical piece indicated in the picture below. I can spin it freely and lift it up slightly as you can see with the pick tool in the picture. The other two props I have do not have this piece move-able. Is this considered a "spun prop"?
Thanks!
Dave
Thanks!
Dave
