I've seemed to have lost power enough to not plane out. After rebuilding the dual carbs, still same problem. Then on a closer look I noticed the main spark wire coming from the power pack and leading up under the flywheel appeared to be melted at both spots where they are held to the motor on little brackets with a rubber grommet surrounding the wire , like your spark plug wires are kept away from your vehicles engine hot spots to prevent melting. The high intensity wire was bare and grounding to the bracket. Now I have a very faint white spark on one cylinder and nothing on the other three. Is my power pack fried. !968 V4 65 hp. Thanks Mars
