Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
1989 90HP Johnson VRO (No spark on two cylinders)
  • 1989 90HP Johnson VRO (No spark on two cylinders)
    Hi I have a 1989 90 hp. Johnson vro. I was having problems with starting the motor so I looked at the fuel system and all checked out ok. So I looked for spark and I found that the right two cylinders have a good strong spark but the left two cylinders spark for 2 seconds and then nothing. Please help me I don't think its the coils but I might be wrong.
    Re: 1989 90HP Johnson VRO (No spark on two cylinders)
    Hi ya' TX.....welcome to iboats.If your 90 is equipped with two power packs, swap them out and see if the problem changes sides. If the problem swaps with the power packs, the power pack is at fault and needs replaced.
    When in doubt...use the manual
    Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
    • #3
      Tx, I had the same problem with an 89 110 I used to have. It just had 1 powerpack not sure if a 90 has 1 or 2 but if it isn't the powerpack it might be the trigger (timer base) that was the problem with mine. With a bad trigger you lose spark to 2 cyls on the same side.
      • #4
        • #5
          Yes it only has I powerpack
          • #6
            Also, What is the trigger/, and where would it be located?
            • #7
              It is located under the flywheel, there are 2 rings under the flywheel the outer one is the stator the inner ring is the trigger. It is shaped like a doughnut. Now I have some good news and some bad news. The bad news is it costs over $200 if it is bad. But I just saved a ton of money by switching to Geico.
              • #8
                Is there a way to check to see if it is good or bad?, if so how do I do this?
                • #9
                  Here are some troubleshooting tips: http://outboardparts.com/troubleshoo...eshooting6.htm
                  • #10
                    Thanks for all your help. The problem was the p/p and now she runs great I thank you and Whatcha Thinking thanks you.
