after 20 seconds at wide open throttle the engine stalled. checked primer ball at the tank and it was soft and wouldnt pump back up.. checked carb bowls, they were almost empty. I want to replace primer closer to the engine. then replace fuel line, then rebuild the engine fuel pump. Am I on the right track??
thanks,
thanks,
