Last season on my last camping trip I broke the large nipple on the primer that connects to fuel pump out and carb in via a tee. I tried to bypass the solenoid by rerouting the lines, it didn't work. Got a new solenoid and can't remember the original hook up.
There is the large nipple, and two smaller nipples left and right, the right side has a tee in it. I need to know where the nipple above the fuelpump line goes, where the left side nipple of the primer solenoid line goes and what does the tee of the right side connect to besides the line that goes to the nipple above the carb to squirt fuel in.
So I have the nipple above the fuel pump, the two small nipples on the primer solenoid, and the nipple above and below the carb on the engine (manifold?) that I need to know the line routing for!!!
A good description or pics would be great....Thanks!!!!
