Engine starts and idles fine on muffs. Starts and idles fine on water but no power. As soon as I try to plane she just dies. I have done a compression test and it resulted in 120,120,120,135. Why is the compression high on one cylinder? The cylinder with high compression also has milky looking substance on plug when I pulled it. All others look fine. I have rebuilt the carbs, new ignition coils, new plug leads and plugs, new gas. I think the problem lies in that high compression cylinder. Logic tells me if its a head gasket the compression should be lower. But the milky substance tells me otherwise. Anyone have this happen. Or have some friendly advise. I'm stuck.
Thanks in advance
Thanks in advance
