Re: evinrude zephyr
How about this for a screaming Zephyr??<br /><br />
<br /><br />As for the impeller, if it is a spoked type impeller, you might be able to modify a currently available style for a 1970s vintage 6hp. If it's the type with the plunger off of one side of a rubber donut, then you might want to check the links off of the AOMCI.org site, as I think there is at least one supplier of that type of impeller there. <br /><br />- Scott
