Hi All,<br /><br />I recently bought a used replacement for my burned out 1980 70 HP Johnson lower unit, and visually everything appears to match up (dimensions, splines, etc.). However, I noticed that on the "new" lower unit, the prop shaft rotates in the opposite direction than on the "old" lower unit, when the shift lever is in a specific gear. Also, the shift rod on the "old" unit has a lot more travel when shifting gears than the "new" one, which moves only a little bit. <br /><br />My first question is, will I need to adjust the shift rod, or the shift linkage, to make sure that it shifts properly? Second, is there any serious problem with me driving around in "reverse" gear to go forward, considering the controls will now be mismatched to the unit?<br /><br />Any help is appreciated!<br />Mark
