Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
85 HP Javelin
  • 85 HP Javelin
    This is my first Johnson motor, so here is the dumb question....It is a 1978 85 HP Javelin Seahorse. Was this motor made for salt water use too? Also, is it better to replace just the impeller, or rebuild the whole water pump? The motor has been sitting for a couple of years.
    2005 Stratos 191 FS 150HP Yamaha
    Re: 85 HP Javelin
    Stumpys, The best thing that you can do with the water pump is to go ahead and replace all the components. You are going to have the lower unit removed. Go ahead and replace the cup, impeller, and wear plate, and gaskets. All of those items should be in the kit. Better to do the job once, then several times.
    • #3
      Re: 85 HP Javelin
      And yes, you can run it in saltwater. Just flush out the motor with fresh water every time you pull the boat out.
      Rick
      "Boating is Life...All the rest is just Details"
      2007 Bentley 200 Cruise
      2007 Merc. 90 4 stroke
      • #4
        Re: 85 HP Javelin
        Thanks.... I figured that I had better do it right the first time.
