dalejunior91
- Mar 28, 2015
- 4
Hi, I can't figure out where the cylinder drain valve is located? I was wondering if there is 1 for each cylinder or just one for all 6?
My spark plugs have been fouling out. I had the carbs rebuilt and it didn't fix the problem. So I did some reading online and it said that it was either the Carbs or this mysterious Cylinder drain check valve. My motor seems like it has been running rich on idle and at high RPM's.
Thanks in advance for the help
