I have a 1993 johnson 90hp that has a broken tilt trim unit. It has a good pump motor, but will not lift. The person I bought it from said that the piston needed to be rebuilt. I tried to jack the motor up to access the trim unit but it will only go up 3 or 4 inches. I am thinking that is not normal. Wouldn't it still be able to be jacked up all the way manually? Is something inside the unit jamming it?
