SpamPutney
- May 3, 2001
- 30
I have a 1980 Johnson 70hp. Runs perfect in driveway at all speeds. Idles great in the water. AS soon as throttle is opened up, ups and dies. Can adjust choke to keep engine running at WOT, but won't idle at that setting. Also, WOT only gives about half the speed it should. Cleaned and rebuilt carbs, no change. Had a professional clean and rebuid carbs, still no change. Compression is perfect. Any ideas? Thanks
