My 1980 Evinrude 100HP is suddenly not running right. rebuilt the whole powerhead last year, with carbs and also replaced the power packs this past summer. New plugs this month as well.
It fires up and idle seems to be okay but when I get on it it seems like its misfiring or running on not all cylinders. Almost the same feeling when one of the power packs went bad. Being that the power packs are both new, I am inclined to believe that they are not bad again. Seems like definitely some sort of ignition issue though. Plugs and wires are brand new. Could this be a coil? Last time I took it out it would run fine at WOT and then suddenly start cutting in and out (loosing power and then taking off again.) By time I got back to the dock it seemed to be worse. But it does seem sporadic. How can I test the coils if this is a possible issue?
thanks guys.
thanks guys.
