I have a 1966 33 HP Evinrude with the factory (I'm assuming) generator kit installed. The boat has the ammeter, start switch, control box, etc. and the motor has a Prestolite Generator installed. The generator does not have a belt so I'm curious what the part number is for the belt on this particular setup. I'm also curious if there is a way to determine if the generator is actually working prior to me spending the money on the belt.
Thanks in advance!
Thanks in advance!
