I have a 1995 Johnson, model number J115GLEOC. I've been wanting to replace the water pump on my motor but have been struggling to disconnect the shift rod and drop the lower unit. I have disconnected the shift/throttle cables but cant seem to get the shift rod to pop off the pin. There doesn't seem like there is enough room to even move the rod off the pin. I have moved through the gears and tried to get as much room as possible but still can't get it to go. Any suggestions? Thanks, Jeff.
