mattairconman9
- Jul 10, 2004
- 8
While cruising around my motor cut down to 1/2 speed, 30 seconds later I got an awful knocking noise in 1 cylinder. I pulled the plug and found 1 was smashed, so I yanked the whole thing apart only to find the caged bearing @ the crankshaft (the bearing close to the split) blew out and wound up in the piston cylinder, smashing it apart. It didn't look like like the plugs fouled and besides the hammering the piston looked fine.<br />The night before it went to 1/2 speed and stalled then I turned the ignition and it fired right up and ran fine the rest of the night.<br />HELP. Im rebuilding it now but want to determine the cause before I start it up.
