boatcrazee1
- Jul 12, 2004
- 2
I have a 1985 Evunrude with tilt/trim that is not charging the battery. Charging coil ohms good, no short to ground or physical damage seen. Voltage from charging coil on test load is 20-30 volts ac.<br /><br />Still nothing from second regulator. Is it possible that I am unlucky and got a bat regulator again? Any testing hints for the regulator or other possible soulutions appreciated.
