Dave Turner
- Mar 7, 2006
- 118
Runs like it should at w.o.t. and then just quits. Starts back up and runs fine then it will quit again after cruising awhile. This model has the internal tank and has the pulse /vac. system with the little orange bladder in the carb inlet. (part #0324661) I pulled the bladder out and would like to know. Is there supposed to be a little slit in the end of the bladder? This one has a slit about a 1/16 of an inch in the end of the bladder that goes into the carb.
The cap is vented and I changed the coil. I hope it isn't the power pack breaking down. I had one go bad on one cylinder on a motor but still ran. This motor just shuts down right now. Thanks
