Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Raker Prop
  • Raker Prop
    Like all other guys with boats,I am in a neverending quest to pickup a few more mph.I have heard great things about the Raker prop's.I do not want to commit to buying one until I know what pitch/diameter is right for my set-up.The motor is a 1993 Johnson 120 hp t/t on a 19 ft alum boat.I know I need more bow lift,and I heard the raker will do this.EDIT: Sorry Mrtool. No soliciting allowed. Try the Want Ads.
    Re: Raker Prop
    I have a 24P raker on my '86 120 HP looper pushing an 18' Hydrostream (bowrider, paded V, about 1400 lb with motor and me) I get great holshots and a top speed of 60 MPH. Very pleased with it. I would suggest that, if possible, you work with your dealer to make sure that the choice of prop is suitable for your needs.
    • #3
      Re: Raker Prop
      The Raker will give you lots of bow lift. My guess is you are running a 19 in aluminium right now? If so, and you are getting about 5400 rpm a 20 in raker should be ok. I had a 18 ft deep vee fibreglass with a 150 Ficht. With the 19 alum it did 5500 rpm at 49mph, I put on a 20 Raker top speed went up to 56mph @ 5400rpm. Also the boat road higher out of the water and had much more bow lift. It also handled much better. When I traded in the boat on a new I/O I kept the prop, had it rehubbed for the I/O. I also tried a 22 raker, my rpms dropped to 4800 rpm and top speed was about the same. Stiletto props have a blade geometry similar to a Raker
      • #4
        Re: Raker Prop
        mrtoolsome dealers will allow you to test a series of props until you get one that works to your liking. You need a tach and run her in somewhere around 5500+.
        Show me a good loser and I'll show you a loser.
