boxchevyman
- Mar 16, 2014
- 61
1975 85hp Johnson.
Model: 85ESL75E
So i bought this motor from a guy that said it was ready to hit the water everything was fine. I ran it on muffs and saw water coming out the thermostat exhaust ports and thought i was golden.
I took it out that Saturday floored it and 50 yards later the overheating buzzer came on. shut it off let it cool a bit then turned around a took it out and home. Later i went looking a little further and checked some hoses. I attached a video of that. I also took the lower unit off and sure enough the impeller was SHOT and shattered.
So i am now going to buy the kit with the new housing and impeller and put all that on.
I have a few quick questions,
1. Seeing what the impeller looks like do you think i have little bits of it in my water jacket?
2. How should i clean the drive shaft so that the impeller will slide smoothly on?
3. Do you think any permanent damage was done running it hot for a few minutes?
Thanks all!
James
Model: 85ESL75E
Thanks all!
James
