Re: Johnson 9.9 sailmaster Only runs with choke closed
Ed Mc., <br />Funny you should mention that!! I talked to the local shop about taking the engine in, as I was ready to give up, and he said he wouldn't be able to look at it for a week. He said in the meantime I should take another crack at cleaning the carb and make sure I got all the ports. When I had it apart this time, I happened to look at the very thing you mentioned (plastic float bowl with perverted fixture). I ran a strand of wire through it, and lo and behold, gunk, wonderful gunk! A little Heimlich maneuver for my carb! I can see light through that jet now, and it explains most of the problems I was having. Question: would that also affect the choke issue?<br /><br />On another front, I figured out how to remove the carb without taking off the auto-rewind starter of death. I removed the top plate from the carb, unscrewed the cam follower mechanism, replaced the top plate to protect the metal body of the carb, and voila! I could squeak in a small wrench to loosen the nuts to finger strength. Just be careful not to lose the nuts, or have a long piece of stiff wire ready to recover them from the bottom of the power head housing.<br /><br />I'll be testing it again on Friday.<br /><br />E
