I have a 1996 Johnson 225 ocean runner and when replacing batterys I hooked up the no. 2 battery back wards since the perko switch was off I didn't know it. I think I kill the rectifier since it burnt off the hot terminal to the battery. I discharged the no. 2 battery to 5 volts and started the motor with the no.1 battery ran it up to about 2500 RPM and check the battery with volt meter and it showed no change switched to the no. 2 battery and checked there was now change. Is there any other test I can do before going and buying a new rectifier/regulator for $200. plus dollars
