took fuel pump apart .. diaphram has no hole or cracks and springs are good... b4 I get a new or<br />fuel pump rebuild kit should I push a wire into the cylinder pressure port hole [ may be clogged] or is there a check devise inside the motor that I will damage?<br /><br />tx for help ken
