Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Electric shift, gear lube?
  • Electric shift, gear lube?
    I have a 1970 60hp Evinrude with electric shift. Does this take a different type of gear oil? I just got the boat and changed the lube using regular lower unit oil. Ran the boat twice, shifts fine.
    Re: Electric shift, gear lube?
    You need OMC "Type C " also known as "OMC Premium Blend " ,Do NOT use any other oil.Now with the Bombardier logo/name + Johnson/Evinrude, still Premium Blend .
    My engines :
    Mercury TII, next project
    Johnson V4m-10s 90 hp 1964,from the prosess.
    Mercury L6 ,Rebuilding a Tower
    • #3
      I was told (yesterday) at the marina to not worry about finding the proper lube if my unit was shifting ok. They said the demand for the electric shift oil is so low that they no longer carry it. They also said that the electric shift oil is just a little thinner than normal lower unit lube. What are the problems associated with using normal lower unit oil? Should I worry? Thanks
